ONEX #54 Web Site
Date:  1-18-2013
Number of Hours:  4.00
Manual Reference:  C02
Brief Description:  Control system assemblies
Fabricated flap handle, C02-08. Enlarged the holes on the flap mount blocks for a smooth fit on the flap drive tube. I used a 1" diameter 80 grit flap wheel (Forney brand PN 60191) mounted in the drill press to ream the ID of the blocks until I had a good fit. I used the same method on the rudder blocks.
Assembled the control stick-to-frame assembly, C02-01.
Enlarging control block hole
Flap, stick and rudder assemblies
